iPi Recorder Release Notes
Revision as of 09:34, 13 June 2024 by Andrew (Talk | contribs)
ver. 4.7.0.98
Version 4.7.0.98
Jun 13, 2024
Download-24.png  Download
 N E W    F E A T U R E S:
ver. 4.6.8.97
Version 4.6.8.97
Apr 21, 2023
 B U G    F I X E S:
  • Fixed bug in Live tracking for multiple Azure Kinect depth sensors configuration.
ver. 4.6.7.96
Version 4.6.7.96
Sep 26, 2022
 B U G    F I X E S:
  • Fixed noise issue with PS3 Eye cameras (red/yellow noise that appears in the images captured if areas are bright).
ver. 4.6.6.95
Version 4.6.6.95
Jul 13, 2022
 B U G    F I X E S:
  • Fixed loss of gyro data on saving .iPiVideo from editor.
  • Fixed inaccurate frame rate evaluation during recording in case of intensive frame drops.
ver. 4.6.5.94
Version 4.6.5.94
Dec 13, 2021
 B U G    F I X E S:
ver. 4.6.1.90
Version 4.6.1.90
Jun 17, 2021
 B U G    F I X E S:
ver. 4.6.0.89
Version 4.6.0.89
Jun 04, 2021
Camera orientations
ver. 4.5.0.84
Version 4.5.0.84
Feb 23, 2021
Intel RealSense L515
Intel RealSense D455
ver. 4.4.6.83
Version 4.4.6.83
Dec 7, 2020
Wired sync mode
 B U G    F I X E S:
ver. 4.4.5.82
Version 4.4.5.82
Feb 28, 2020
 B U G    F I X E S:
ver. 4.4.4.81
Version 4.4.4.81
Oct 9, 2019
 B U G    F I X E S:
ver. 4.4.0.77
Version 4.4.0.77
Aug 23, 2019
ver. 4.3.2.75
Version 4.3.2.75
Aug 3, 2019
 B U G    F I X E S:
ver. 4.3.1.74
Version 4.3.1.74
May 16, 2019
ver. 4.3.0.73
Version 4.3.0.73
Mar 22, 2019
 B U G    F I X E S:
ver. 4.2.2.72
Version 4.2.2.72
Feb 26, 2019
 B U G    F I X E S:
ver. 4.2.1.71
Version 4.2.1.71
Feb 18, 2019
 B U G    F I X E S:
ver. 4.2.0.70
Version 4.2.0.70
Feb 5, 2019
Add Device dropdown
ver. 4.1.0.69
Version 4.1.0.69
Dec 3, 2018
ver. 4.0.7.67
Version 4.0.7.67
Sep 6, 2018
 B U G    F I X E S:
ver. 4.0.5.65
Version 4.0.5.65
Aug 24, 2018
 B U G    F I X E S:
ver. 4.0.4.64
Version 4.0.4.64
Aug 13, 2018
 B U G    F I X E S:
ver. 4.0.3.63
Version 4.0.3.63
Jul 19, 2018
 B U G    F I X E S:
ver. 4.0.1.61
Version 4.0.1.61
Jul 03, 2018
 B U G    F I X E S:
ver. 3.3.2.57
Version 3.3.2.57
Oct 23, 2017
 B U G    F I X E S:
ver. 3.3.1.56
Version 3.3.1.56
Oct 13, 2017
 B U G    F I X E S:
ver. 3.3.0.55
Version 3.3.0.55
Aug 14, 2017
 B U G    F I X E S:
ver. 3.2.11.53
Version 3.2.11.53
Jun 12, 2017
 B U G    F I X E S:
ver. 3.2.9.51
Version 3.2.9.51
Apr 28, 2017
 B U G    F I X E S:
ver. 3.2.8.50
Version 3.2.8.50
Apr 25, 2017
 B U G    F I X E S:
ver. 3.2.7.49
Version 3.2.7.49
Mar 07, 2017
 B U G    F I X E S:
ver. 3.2.6.48
Version 3.2.6.48
Jan 25, 2017
 B U G    F I X E S:
ver. 3.2.5.47
Version 3.2.5.47
Nov 10, 2016
 B U G    F I X E S:
ver. 3.2.3.45
Version 3.2.3.45
Jul 14, 2016
ver. 3.1.4.43
Version 3.1.4.43
Apr 25, 2016
ver. 3.1.3.38
Version 3.1.3.38
Nov 19, 2015
  • Memory usage optimizations.
ver. 3.1.2.36
Version 3.1.2.36
Jun 18, 2015
 B U G    F I X E S:
ver. 3.1.1.34
Version 3.1.1.34
Mar 06, 2015
 B U G    F I X E S:
ver. 3.1.0.33
Version 3.1.0.33
Dec 29, 2014
 B U G    F I X E S:
ver. 3.0.1.32
Version 3.0.1.32
Nov 13, 2014
 B U G    F I X E S:
ver. 3.0.0.31
Version 3.0.0.31
Nov 03, 2014
