Cameras and Accessories
- Very good low-light sensitivity.
- Low-distortion wide-angle fixed optics.
- Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams).
- Low cost (under $40).
The only downside of PlayStation Eye is its lack of tripod mounting screw. Possible solutions:
Cables
Tripods
Video Card
USB controllers
All modern computers (e.g. dual-core and better) based on Intel, AMD and Nvidia chipsets have at least two high-speed USB (USB 2.0) controllers on board. With 2 controllers you've got enough bandwidth to record with:
USB hubs
Known compatibility issues
