Cameras and Accessories
Sony PlayStation Eye for PS3
Logitech C922
- 60 FPS for 720p resolution.
- Tripod mounting screw.
Cameras Comparison
Which camera to choose?
PS Eye | PS Eye transfers images in Bayer format to computer, after that iPi Recorder subtracts background, compresses and writes to disk. All these operations are highly optimized and efficient. Logitech C922, in turn, sends images in (M)JPEG format to computers, and iPi Recorder simply writes these JPEG frames on disk. But iPi Recorder also has to unpack JPEG images to generate on-screen preview and evaluate change of background. This results in additional CPU load during recording in case of using of Logitech C922. |
Cables
Tripods
Video Card
USB controllers
All modern computers (e.g. dual-core and better) based on Intel, AMD and Nvidia chipsets have at least two high-speed USB (USB 2.0) controllers on board. With 2 controllers you've got enough bandwidth to record with:
USB hubs
Known compatibility issues
