Cameras and Accessories
Sony PlayStation Eye for PS3
Logitech C922
- 60 FPS for 720p resolution.
- Tripod mounting screw.
Cameras Comparison
Which camera to choose?
| image quality | good-enough (but poor in low light conditions) |
good (good-enough in low light conditions) |
C922 | But image quality is not so critical for iPi Motion Capture. |
PS Eye | CPU load is higher as well when recording with Logitech C922. |
Action Cameras
Starting from v4 of iPi Motion Capture solution you can use stand-alone cameras instead of web cameras. These stand-alone cameras must match the following requirements to be usable with iPi Motion Capture:
- Fixed optics (if camera has auto-focus and zoom features, they must be turned off before recording)
- High FPS (at least 60 FPS at 720p resolution)
- Wide field-of-view (at least 90° in diagonal)
Action cameras fit to all of these requirements. The most popular models here are:
Web Cameras vs. Action Cameras
The overall workflow with action cameras is more complicated and even tricky than with action cameras. See Quick Start Guide for Multiple Action Cameras Configuration for details. But in spite of it, using of action cameras has some advantages:
| Configration | Pros | Cons |
| Web Cameras |
| Action Cameras |
Cables
Tripods
Video Card
USB controllers
All modern computers (e.g. dual-core and better) based on Intel, AMD and Nvidia chipsets have at least two USB 2.0 controllers on board. With two USB 2.0 controllers you've got enough bandwidth to record with:
- or 4 cameras at 640x480 at 60 FPS
- or 6 cameras at 640x480 at 40 FPS
Some modern laptops have both USB 2.0 and 3.0 controllers. In this case single USB 3.0 controller can handle with four PS Eye cameras at 640x480 at 60 FPS.
You should make sure that you have depth sensors or cameras evenly distributed between available USB 2.0 (or 3.0) controllers. For example, if you have four PS Eye cameras, you should connect two cameras to first controller and two cameras to second controller. (But some USB 3.0 controllers can work with four cameras.) Device Manager usually shows USB cameras as “USB Composite Device” at the “Advanced” tab of USB controller properties. If you have too many cameras connected to single USB 2.0 / 3.0 controller, you should re-plug them to different USB ports.
USB hubs
If several devices are connected on the USB hub and working in parallel, then the USB bandwidth is shared among the devices. Connecting all cameras via single USB 2.0 hub is OK only for low resolution video recording (320x240). To be able to record video at 640x480 and 60 frames per second, you should avoid connecting more than 2 cameras via single USB 2.0 controller and more than 4 cameras via some models of USB 3.0 controllers.
Known compatibility issues
