Revision as of 05:46, 2 December 2021 by Pavel (Talk | contribs)
ver. 4.5.2.252
Version 4.5.2.252
Dec 02, 2021
Download-24.png  Download
 E N H A N C E M E N T S:
 B U G    F I X E S:
ver. 4.5.1.250
Version 4.5.1.250
Jun 17, 2021
 B U G    F I X E S:
ver. 4.5.0.249
Version 4.5.0.249
Jun 04, 2021
 N E W    F E A T U R E S:
  • Support for videos recorded in Portrait and Upside down orientations
ver. 4.4.1.243
Version 4.4.1.243
Feb 24, 2021
 B U G    F I X E S:
ver. 4.4.0.242
Version 4.4.0.242
Feb 9, 2021
ver. 4.3.1.240
Version 4.3.1.240
Feb 28, 2020
 B U G    F I X E S:
ver. 4.3.0.239
Version 4.3.0.239
Oct 9, 2019
ver. 4.2.0.235
Version 4.2.0.235
Aug 23, 2019
ver. 4.1.3.233
Version 4.1.3.233
May 16, 2019
    • improved tips
 B U G    F I X E S:
ver. 4.1.1.231
Version 4.1.1.231
Dec 27, 2018
ver. 4.1.0.230
Version 4.1.0.230
Dec 03, 2018
 B U G    F I X E S:
ver. 4.0.3.226
Version 4.0.3.226
Sep 06, 2018
 B U G    F I X E S:
ver. 4.0.2.225
Version 4.0.2.225
Aug 17, 2018
 B U G    F I X E S:
ver. 4.0.1.224
Version 4.0.1.224
Jul 26, 2018
 B U G    F I X E S:
ver. 4.0.0.223
Version 4.0.0.223
Jul 03, 2018
ver. 3.6.6.222
Version 3.6.6.222
Mar 06, 2018
    • Higher speed.
    • Slightly better accuracy.
 B U G    F I X E S:
ver. 3.6.4.220
Version 3.6.4.220
Jun 17, 2017
 B U G    F I X E S:
ver. 3.6.3.219
Version 3.6.3.219
May 29, 2017
 B U G    F I X E S:
    • App crash
    • Visual glitches
ver. 3.6.2.218
Version 3.6.2.218
May 26, 2017
 B U G    F I X E S:
ver. 3.6.1.217
Version 3.6.1.217
May 25, 2017
 B U G    F I X E S:
ver. 3.6.0.216
Version 3.6.0.216
May 25, 2017
    • Vastly greater speed
  • Automation add-on:
 B U G    F I X E S:
ver. 3.5.1.215
Version 3.5.1.215
Apr 23, 2017
 B U G    F I X E S:
ver. 3.5.0.214
Version 3.5.0.214
Apr 19, 2017
 B U G    F I X E S:
ver. 3.4.16.212
Version 3.4.16.212
Nov 29, 2016
 B U G    F I X E S:
ver. 3.4.15.211
Version 3.4.15.211
Nov 29, 2016
 B U G    F I X E S:
  • Fixed GPU memory leaks.
ver. 3.4.12.208
Version 3.4.12.208
Oct 13, 2016
ver. 3.3.10.206
Version 3.3.10.206
Sep 23, 2016
 B U G    F I X E S:
ver. 3.3.9.205
Version 3.3.9.205
Sep 15, 2016
 B U G    F I X E S:
ver. 3.3.8.204
Version 3.3.8.204
Sep 01, 2016
 B U G    F I X E S:
ver. 3.3.7.203
Version 3.3.7.203
Jul 14, 2016
ver. 3.2.7.201
Version 3.2.7.201
May 03, 2016
 B U G    F I X E S:
ver. 3.2.6.200
Version 3.2.6.200
Apr 25, 2016
 N E W    F E A T U R E S:.
ver. 3.2.5.193
Version 3.2.5.193
Nov 19, 2015
 B U G    F I X E S:
ver. 3.2.4.191
Version 3.2.4.191
Aug 24, 2015
 B U G    F I X E S:
ver. 3.2.3.190
Version 3.2.3.190
Aug 08, 2015
 B U G    F I X E S:
ver. 3.2.2.189
Version 3.2.2.189
Jun 17, 2015
 B U G    F I X E S:
ver. 3.2.1.187
Version 3.2.1.187
May 02, 2015
 B U G    F I X E S:
ver. 3.2.0.182
Version 3.2.0.182
Apr 20, 2015
    • legs length;
    • arms length;
    • shoulders width;
    • head size;
    • feet size.
ver. 3.1.2.177
Version 3.1.2.177
Mar 19, 2015
ver. 3.1.1.175
Version 3.1.1.175
Feb 24, 2015
 B U G    F I X E S:
ver. 3.1.0.173
Version 3.1.0.173
Feb 20, 2015
 B U G    F I X E S:
ver. 3.0.3.172
Version 3.0.3.172
Jan 07, 2015
 B U G    F I X E S:
ver. 3.0.2.171
Version 3.0.2.171
Nov 26, 2014
  • Options for FBX export:
    • FBX version;
    • Binary/ASCII format.
  • Reduced memory footprint.
 B U G    F I X E S:
ver. 3.0.1.169
Version 3.0.1.169
Nov 11, 2014
 B U G    F I X E S:
ver. 3.0.0.166
Version 3.0.0.166
Nov 03, 2014
  • Improved calibration:
    • more reliable;
    • faster;
    • automatic ground detection;
  • Redesigned user interface.
  • Migration to DirectX 11.
