Cameras and Accessories
Revision as of 04:35, 31 January 2022 by Vmaslov (Talk | contribs)
Sony PlayStation Eye for PS3
Logitech C922
  • 60 FPS for 720p resolution.
  • Tripod mounting screw.
Cameras Comparison
Which camera to choose?
field of view diagonal: 75°
horizontal: 63°
vertical: 49.5°
diagonal: 78°
horizontal: 70°
vertical: 43°
image quality good-enough
(but poor in low light conditions)
good
(good-enough in low light conditions)
connection USB 2.0
(up to 2-4 cameras per USB-controller)
USB 2.0
disk usage
(for six cameras)
25 MB/sec
640x480@60
(background subtraction)
35 MB/sec
1280x720@60
Action Cameras
Note: Stand-alone cameras support in available starting from v4 of iPi Motion Capture.
Tip: The most practical resolution for full body motion capture is 720p that is 1280 x 720. Using higher resolutions adds technical complications but does not give substantial advantages.
GoPro HERO5 Black
SJCAM M20 WiFi
YI 4K
Note: If you select action cameras specially for iPi Motion Capture, you can use almost any cheap action camera model which supports 720p (1280 x 720) resolution at 60 or 90 FPS. At least, there is no need to choose cameras that support 4K video because such high resolution is not practical for iPi Motion Capture.
Web Cameras vs. Action Cameras
Configration Pros Cons
Web Cameras
  • Requires rather powerful PC(s) for recording:
    • many USB ports
    • several USB controllers
    • fast storage system
    • fast CPU
  • A lot of USB cables on the floor
  • View angle (FOV) is not wide enough to be used in small rooms
Action Cameras
  • No need in PC and external power supply for recording (high mobility)
  • No USB cables on the floor
  • Wider view angle (FOV) results in bigger capture volume
  • Wider view angle allows to record in smaller rooms
  • 90 and even 120 FPS (depends on the model of action camera and lighting conditions)
  • Intrinsic parameters of each camera must be determined in advance (camera optics calibration)
  • A few manual and time consuming steps are required to get multi-camera synchronized video:
  • Right now there is no simple way to use Motion Controllers with action cameras
Cables
Tripods
Video Card
Note: Professional GPUs like NVIDIA Quadro or AMD FirePro are not recommended due to high price and lack of performance advantage. You should understand that Quadro/FirePro video cards are designed for very specific professional OpenGL-based workloads. Their main advantage is high image quality in OpenGL rendering. iPi Motion Capture needs raw 32-bit floating point performance and does not benefit from image quality features of Quadro/FirePro video cards. For best performance, use top gaming-class video cards from NVIDIA or AMD.
USB controllers
Note: In case of using of action cameras there is no special requirements for USB controllers.
All modern computers (e.g. dual-core and better) based on Intel, AMD and Nvidia chipsets have at least two USB 2.0 controllers on board. With two USB 2.0 controllers you've got enough bandwidth to record with:
  1. 2 depth sensors (first generation Microsoft Kinect)
  2. or 4 cameras at 640x480 at 60 FPS
  3. or 6 cameras at 640x480 at 40 FPS
Some modern laptops have both USB 2.0 and 3.0 controllers. In this case single USB 3.0 controller can handle with four PS Eye cameras at 640x480 at 60 FPS.
Important! Kinect 2 for Windows, Kinect for Xbox One requires USB 3.0 controller. Kinect SDK 2.0 supports only single sensor on one PC. Libfreenect2 supports multiple sensors on one PC.
You should make sure that you have depth sensors or cameras evenly distributed between available USB 2.0 (or 3.0) controllers. For example, if you have four PS Eye cameras, you should connect two cameras to first controller and two cameras to second controller. (But some USB 3.0 controllers can work with four cameras.) Device Manager usually shows USB cameras as “USB Composite Device” at the “Advanced” tab of USB controller properties. If you have too many cameras connected to single USB 2.0 / 3.0 controller, you should re-plug them to different USB ports.
USB hubs
Note: In case of using of action cameras there is no need in these USB hubs.
If several devices are connected on the USB hub and working in parallel, then the USB bandwidth is shared among the devices. Connecting all cameras via single USB 2.0 hub is OK only for low resolution video recording (320x240). To be able to record video at 640x480 and 60 frames per second, you should avoid connecting more than 2 cameras via single USB 2.0 controller and more than 4 cameras via some models of USB 3.0 controllers.
  • For desktops you can use PCI USB controllers.
  • For laptops there are USB controllers for ExpressCard and eSATA slots.
Important! Please refer to Potential issues with USB controllers and Known compatibility issues sections below before buying a controller.
Important! Before buying a specific laptop model it is strongly recommended to ensure it has the sufficient number of available built-in USB controllers and they are compatibile with cameras you intend to use. Find it at your local retailer, and bring cameras with you to test. Though it may be easier if your friend/neighbour has such a laptop. Or ask at our forum, maybe someone already used this model with our software or can recommend specific model for your camera configuration.
Additional USB controllers needed for multiple Kinects.
One user reports that uninstalling Intel USB 3.0 driver resolves the issue.
Microsoft Kinect v2 Etron EJ168 No data coming from device.
Microsoft Kinect v2 VIA VL800 No data coming from device.
