Cameras and Accessories
Revision as of 05:34, 31 January 2022 by Vmaslov (Talk | contribs)
Sony PlayStation Eye for PS3
Logitech C922
  • 60 FPS for 720p resolution.
  • Tripod mounting screw.
Cameras Comparison
Which camera to choose?
field of view diagonal: 75°
horizontal: 63°
vertical: 49.5°
diagonal: 78°
horizontal: 70°
vertical: 43°
image quality good-enough
(but poor in low light conditions)
good
(good-enough in low light conditions)
connection USB 2.0
(up to 2-4 cameras per USB-controller)
USB 2.0
disk usage
(for six cameras)
25 MB/sec
640x480@60
(background subtraction)
35 MB/sec
1280x720@60
Action Cameras
Note: Stand-alone cameras support in available starting from v4 of iPi Motion Capture.
Tip: The most practical resolution for full body motion capture is 720p that is 1280 x 720. Using higher resolutions adds technical complications but does not give substantial advantages.
GoPro HERO5 Black
SJCAM M20 WiFi
YI 4K
Note: If you select action cameras specially for iPi Motion Capture, you can use almost any cheap action camera model which supports 720p (1280 x 720) resolution at 60 or 90 FPS. At least, there is no need to choose cameras that support 4K video because such high resolution is not practical for iPi Motion Capture.
Web Cameras vs. Action Cameras
Configration Pros Cons
Web Cameras
  • Requires rather powerful PC(s) for recording:
    • many USB ports
    • several USB controllers
    • fast storage system
    • fast CPU
  • A lot of USB cables on the floor
  • View angle (FOV) is not wide enough to be used in small rooms
Action Cameras
  • No need in PC and external power supply for recording (high mobility)
  • No USB cables on the floor
  • Wider view angle (FOV) results in bigger capture volume
  • Wider view angle allows to record in smaller rooms
  • 90 and even 120 FPS (depends on the model of action camera and lighting conditions)
  • Intrinsic parameters of each camera must be determined in advance (camera optics calibration)
  • A few manual and time consuming steps are required to get multi-camera synchronized video:
  • Right now there is no simple way to use Motion Controllers with action cameras
Cables
Tripods
Video Card
Note: Professional GPUs like NVIDIA Quadro or AMD FirePro are not recommended due to high price and lack of performance advantage. You should understand that Quadro/FirePro video cards are designed for very specific professional OpenGL-based workloads. Their main advantage is high image quality in OpenGL rendering. iPi Motion Capture needs raw 32-bit floating point performance and does not benefit from image quality features of Quadro/FirePro video cards. For best performance, use top gaming-class video cards from NVIDIA or AMD.
USB controllers
Note: In case of using action cameras there are no special requirements for USB controllers.
All modern computers based on Intel and AMD chipsets have at least one combined USB 3.1 (or 3.0) / USB 2.0 controller on board. It is usually capable of handling either of:
  • 2 USB 2.0 depth sensors (e.g. Microsoft Kinect v1)
  • 1 or 2 USB 3.0 depth sensors (e.g. Microsoft Azure Kinect), depending on a specific sensor model and whether an RGB stream is recorded
  • 4 USB 2.0 RGB cameras at 640x480 at 60 FPS (e.g. PS Eye)
  • 6 USB 2.0 RGB cameras at 640x480 at 40 FPS (e.g. PS Eye)
Some PCs may have additional USB controllers built-in. You can check how many USB controllers you have in the Universal Serial Bus controllers section in the Device Manager. USB controllers.png
Tip: Kinect 2 for Windows, Kinect for Xbox One requires a separate USB 3.0 controller per device. However, the standard driver (Kinect SDK 2.0) supports only single sensor per PC (this is a software limitation). An alternative Libfreenect2 driver supports multiple Kinect 2 sensors on one PC.
Modern laptops usually lack options to add more USB controllers. So if you're going to use a laptop for recording with many cameras look for gaming-class products. They often include an additional USB controller and more USB ports than conventional "work-horse" laptops. Besides, due to having a high-performance discrete GPU they can be used for occasional tracking, although employing a desktop GPU for that purpose is a preferred option.
Important! Some USB chips have compatibility issues with specific cameras which may result in not detecting cameras, low frame rate, etc. See the next section on known issues. When getting a PCIe USB card we strongly recommend to look for one based on a NEC/Renesas USB 3.0 chip. It has the best compatibility we've seen so far across various models of cameras and depth sensors.
Important! You can use USB 2.0 or USB 3.0 hubs to connect USB 2.0 cameras. Use only USB 3.0 hubs to connect USB 3.0 cameras. For USB 3.0, prefer active hubs which use an external power supply.
Known compatibility issues
Combinations of camera & USB chip listed below have known compatibility issues. Unfortunately, there is no guarantee that other combinations will work for sure, but most will. If you need an additional USB controller for connecting specific camera, be sure not to get the one based on an incompatible USB chip.
Additional USB controllers needed for multiple Kinects.
One user reports that uninstalling Intel USB 3.0 driver resolves the issue.
Microsoft Kinect v2 Etron EJ168 No data coming from device.
Microsoft Kinect v2 VIA VL800 No data coming from device.
