- 1 ver. 4.6.3.265
- 2 ver. 4.6.2.264
- 3 ver. 4.6.1.263
- 4 ver. 4.6.0.262
- 5 ver. 4.5.8.260
- 6 ver. 4.5.7.258
- 7 ver. 4.5.6.256
- 8 ver. 4.5.2.252
- 9 ver. 4.5.1.250
- 10 ver. 4.5.0.249
- 11 ver. 4.4.1.243
- 12 ver. 4.4.0.242
- 13 ver. 4.3.1.240
- 14 ver. 4.3.0.239
- 15 ver. 4.2.0.235
- 16 ver. 4.1.3.233
- 17 ver. 4.1.1.231
- 18 ver. 4.1.0.230
- 19 ver. 4.0.3.226
- 20 ver. 4.0.2.225
- 21 ver. 4.0.1.224
- 22 ver. 4.0.0.223
- 23 ver. 3.6.6.222
- 24 ver. 3.6.4.220
- 25 ver. 3.6.3.219
- 26 ver. 3.6.2.218
- 27 ver. 3.6.1.217
- 28 ver. 3.6.0.216
- 29 ver. 3.5.1.215
- 30 ver. 3.5.0.214
- 31 ver. 3.4.16.212
- 32 ver. 3.4.15.211
- 33 ver. 3.4.12.208
- 34 ver. 3.3.10.206
- 35 ver. 3.3.9.205
- 36 ver. 3.3.8.204
- 37 ver. 3.3.7.203
- 38 ver. 3.2.7.201
- 39 ver. 3.2.6.200
- 40 ver. 3.2.5.193
- 41 ver. 3.2.4.191
- 42 ver. 3.2.3.190
- 43 ver. 3.2.2.189
- 44 ver. 3.2.1.187
- 45 ver. 3.2.0.182
- 46 ver. 3.1.2.177
- 47 ver. 3.1.1.175
- 48 ver. 3.1.0.173
- 49 ver. 3.0.3.172
- 50 ver. 3.0.2.171
- 51 ver. 3.0.1.169
- 52 ver. 3.0.0.166
ver. 4.6.3.265
N E W F E A T U R E S:
- AI-based Tracking with Auto-recover option featue added. It allows to automatically detect and fix tracking errors with the help of AI-based tracking.
B U G F I X E S:
- Rare AI-based tracking crashes in some cases.
- Fixed crashing on project closing when Pose Mismatch view mode is on.
U N D E R T H E H O O D:
- AI pose interpolation/filters are only applied if AI attempted to apply in this frame.
ver. 4.6.2.264
- Trajectory filtering for AI poses that improves overall AI-based Tracking quality.
- Interpolation of AI poses missed due to misdetections that improves overall AI-based Tracking quality.
- Improved algorithm for selecting correct bounding box for AI pose tracking that improves overall AI-based Tracking quality.
ver. 4.6.1.263
- Detect Pose (AI) now sets head, feet poses and hands orientation if Track or Track (AI-Based) tracking option selected.
E N H A N C E M E N T S:
- Improved quality of Detect Pose (AI) for arms, legs and feet.
- Set realistic arm and leg twists in Detect Pose (AI) (formerly set zero twists).
- Ensure from enormous arm twists in jitter removal, Detect Pose (AI).
B U G F I X E S:
- Trajectory filtering was not applied after AI-based tracking.
- AI-based feet tracking sometimes returned invalid pose that led to crash.
- Rare crashes in trajectory filtering, jitter removal related to AI-based tracking.
- All passes and jitter removal now process the last frame of Region-of-Interest (last frame inclusive).
- Detect Pose (AI) re-applies the Dnn tracking to take into account the possible changes of actor settings and/or ground plane.
ver. 4.6.0.262
- New tracking features that use modern AI toolkit from NVIDIA:
- New build-in target characters and motion transfer profiles for better compatibility with Unreal Engine 5:
- UE5 Manny
- UE5 Quinn
- Switching to FBX SDK 2020.2.1 for FBX files import/export
ver. 4.5.8.260
B U G F I X E S:
ver. 4.5.7.258
B U G F I X E S:
ver. 4.5.6.256
B U G F I X E S:
ver. 4.5.2.252
B U G F I X E S:
ver. 4.5.1.250
B U G F I X E S:
ver. 4.5.0.249
ver. 4.4.1.243
B U G F I X E S:
ver. 4.4.0.242
ver. 4.3.1.240
B U G F I X E S:
ver. 4.3.0.239
ver. 4.2.0.235
ver. 4.1.3.233
- improved tips
B U G F I X E S:
ver. 4.1.1.231
ver. 4.1.0.230
B U G F I X E S:
ver. 4.0.3.226
B U G F I X E S:
ver. 4.0.2.225
B U G F I X E S:
ver. 4.0.1.224
B U G F I X E S:
ver. 4.0.0.223
ver. 3.6.6.222
- Higher speed.
- Slightly better accuracy.
B U G F I X E S:
ver. 3.6.4.220
B U G F I X E S:
ver. 3.6.3.219
B U G F I X E S:
- App crash
- Visual glitches
ver. 3.6.2.218
B U G F I X E S:
ver. 3.6.1.217
B U G F I X E S:
ver. 3.6.0.216
- Vastly greater speed
- Automation add-on:
true.
B U G F I X E S:
ver. 3.5.1.215
B U G F I X E S:
ver. 3.5.0.214
B U G F I X E S:
ver. 3.4.16.212
B U G F I X E S:
ver. 3.4.15.211
B U G F I X E S:
- Fixed GPU memory leaks.
ver. 3.4.12.208
ver. 3.3.10.206
B U G F I X E S:
ver. 3.3.9.205
B U G F I X E S:
ver. 3.3.8.204
B U G F I X E S:
ver. 3.3.7.203
ver. 3.2.7.201
B U G F I X E S:
ver. 3.2.6.200
N E W F E A T U R E S:.
ver. 3.2.5.193
B U G F I X E S:
ver. 3.2.4.191
B U G F I X E S:
ver. 3.2.3.190
B U G F I X E S:
ver. 3.2.2.189
B U G F I X E S:
ver. 3.2.1.187
B U G F I X E S:
ver. 3.2.0.182
- legs length;
- arms length;
- shoulders width;
- head size;
- feet size.
ver. 3.1.2.177
ver. 3.1.1.175
B U G F I X E S:
ver. 3.1.0.173
B U G F I X E S:
ver. 3.0.3.172
B U G F I X E S:
ver. 3.0.2.171
- Options for FBX export:
- FBX version;
- Binary/ASCII format.
- Reduced memory footprint.
B U G F I X E S:
ver. 3.0.1.169
B U G F I X E S:
ver. 3.0.0.166
- Improved calibration:
- more reliable;
- faster;
- automatic ground detection;
- Redesigned user interface.
- Migration to DirectX 11.
