User Guide for Multiple Depth Sensors Configuration
Revision as of 07:15, 3 November 2014 by Pavel (Talk | contribs)
    • CPU: x86 compatible (Intel Pentium 4 or higher, AMD Athlon or higher, 2GHz), dual- or quad- core is preferable
    • Operating system: Windows 11 / 10 / 8.1 / 8 / 7 (32-bit or 64-bit)
      Important! Kinect 2 for Windows, Kinect for Xbox One requires USB 3.0 controller. Kinect SDK 2.0 supports only single sensor on one PC. Libfreenect2 supports multiple sensors on one PC.
    • ExpressCard or eSATA slot (for laptops)
    • Storage system: HDD or SSD or RAID with write speed:
      • For Kinect 2 for Windows / Kinect for Xbox One sensors:
        • 2 sensors — not less than 66,0 MByte/sec
        • 3 sensors — not less than 99,0 MByte/sec
      • For Microsoft Kinect sensors:
        • 2 sensors — not less than 55,0 MByte/sec
        • 3 sensors — not less than 82,5 MByte/sec
Note: If your write speed is lower, you can use can use background subtraction mode. Alternatively, you can use compressed mode (that gives 3-5 times lower required write speed, but the CPU performance may become a bottleneck)
  • 2 or 3 depth sensors: Microsoft Kinect 2 for Windows / Microsoft Kinect for Xbox One, or Microsoft Kinect
Note: For Microsoft Kinect for Xbox One you will need Microsoft Kinect Adapter cable
iPi Mocap Studio
    • CPU: x86/x64 compatible (Intel Pentium 4 or higher, AMD Athlon or higher), dual- or quad- core is preferable.
    • Operating system: Windows 11 / 10 / 8.1 / 8 / 7 (32-bit or 64-bit).
    • Video card: DirectX 11 capable gaming-class graphics card.
{{Note|Before you start working with multiple depth sensors, it is highly recommended to get appropriate results with single depth sensor configuration: User Guide for Single Depth Sensor Configuration.
Software Installation
  1. Select needed components
Important!
Components
    Device drivers and software libraries for Microsoft Kinect 2. Requires 64-bit Windows 8+ and USB 3.0.
    iPi Recorder itself.
iPi Mocap Studio
All components are required for installation.
Note: The installation of Microsoft .NET Framework 4.8 requires an Internet connection. If needed, you can download offline installer for Microsoft .NET separately, and run it before iPi Mocap Studio setup.
Other components are included with iPi Mocap Studio setup.
Note: Shell Extensions for Video and Project files are needed to show thumbnails and preview for iPi video and project files in Windows Explorer
  1. Press the Install button to begin installation.
  2. You will be prompted to read and accept the license agreement(s) by checking corresponding checkbox.
  3. Press the Install button to begin installation.
  4. Upon installation is complete, you will be prompted to launch iPi Mocap Studio.
  5. As soon as iPi Mocap Studio launches, you will be prompted to enter your license key or start 30-days free trial period.
    For more info about license protection see Licensing Policy.
  6. Ensure that your graphics hardware is set to maximum performance with iPi Mocap Studio.
Recording Video from Multiple Depth Sensors
Environment
Configuration Azure Kinect (WFOV mode) Azure Kinect (NFOV mode)
Kinect 2 (Kinect for Xbox One)
1st gen. Depth Sensors
Orbbec Astra (Pro)
Single Depth Sensor
7 by 5 feet = 2 by 1.5 meters
8 by 5 feet = 2.5 by 1.5 meters
10 by 10 feet = 3 by 3 meters
2 Depth Sensors
(90-degrees config.)
7 by 7 feet = 2 by 2 meters
8 by 8 feet = 2.5 by 2.5 meters
2 Depth Sensors
(180-degrees config.)
12 by 7 feet = 3.5 by 2 meters
16 by 8 feet = 5 by 2.5 meters
20 by 10 feet = 6 by 3 meters
3+ Depth Sensors
12 by 12 feet = 3.5 by 3.5 meters
16 by 16 feet = 5 by 5 meters
20 by 20 feet = 6 by 6 meters
Maximum capture area is about 7 by 7 feet ( = 2 by 2 meters), for all sensor models and configurations.
The pictures below will help you to understand possible capture area and required space. Dimensions are different for Azure Kinect, Kinect 2 (Kinect for Xbox One) and 1st gen. depth sensors due to different field of view.
Azure Kinect in NFOV mode and Kinect 2 for Windows (Kinect for Xbox One)
Kinect 2 (Kinect for Xbox One) sensors and Azure Kinect sensors in NFOV mode (narrow-view mode) have very close view angles (less than Azure Kinect in WFOV mode, but greater than 1st gen. depth sensors and Orbbec Astra):
Side view
Top view
Wide-view mode (WFOV mode) of Azure Kinect has extremely wide view angle:
Side view
Top view
Note: But please be aware that quality of depth map is better in narrow-view mode (NFOV mode). For this reason, if you have enough space, it is recommended to use NFOV mode for Azure Kinect sensors.
First Generation Depth Sensor or Orbbec Astra (Pro)
If you're using outdated 1st generation depth sensor like Kinect v1 or Orbbec Astra (Pro) sensor which is almost the same as 1st gen. depth sensor:
Side view
Top view
Actor Clothing
Recording Process
Calibration
Dual Depth Sensors Configurations
First configuration
Kinect 2
Kinect
Second configuration
Kinect 2
Kinect
Triple Depth Sensors Configuration
Ideally, depth sensors should be placed at apexes of equilateral triangle with sides equal to about 6 meters.
Ideal Configuration for Kinect 2
In practice it may not always be achievable due to available space size and configuration, mount positions, USB and/or power cord lengths, etc. Thus, sensor positions may slightly differ from ideal ones. Please look at the example from real mocap session.
Real-life Scene Configuration Expample
Recording Calibration Video
We use flashlight or other small glowing marker to perform calibration for depth sensors. This calibration procedure is very similar to one used for Multiple Sony PS Eye Cameras Configuration. But in case of depth sensors the overall workflow is simpler:
  • There is no need to touch floor by flashlight during recording.
  • No marking of points as ground in iPi Mocap Studio.
    (depth data is used to detect ground plane automatically)
  • No manual adjustments of scene scale in iPi Mocap Studio.
    (depth data is used to determine scale automatically)
Note: For Dual Depth Sensor configuration you can use calibration based on 3D plane. Accuracy of both methods is the same. Using flashlight marker is recommended as more easy-to-use method.
Glowing Marker
Recording Calibration Sequence
  • Run iPi Recorder.
  • Color stream should be recorded along with depth data. That's why only modes "(depth+color)" can be used.
  • Avoid bright lightening and white objects on background during recording of calibration video.
  • Start recording.
  • Move the marker slowly through your entire capture volume (front-top-right-bottom-left-back-top-right-bottom-left). Start from top and move the marker in a descending spiral motion.
Tip: You should make the marker visible to both depth sensors at all times. Hold the marker in the straight arm away from your body.
Processing Calibration Video
  • Open recorded calibration video in iPi Mocap Studio.
  • Adjust Region-of-Interest so that glowing marker is visible at the beginning and at the end.
  • Click Calibrate Based on Flashlight Marker button.
  • Wait while automatic calibration is performing.
  • Check resulted statistics:
    • Good Frames Count should be at least 100 (500 and higher are recommended values).
    • Average Position Error (meters) should be less than 0.100 (0.050 and lower are recommended values).
600px
  • Save results using Save scene... button on Scene tab.
Recording Actor's Performance
After completing Setup and Background recording steps, press Record button to begin video recording. To stop recording, press Stop button.
Recommended Layout of an Action Video
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-Pose
As soon as recorder starts, go to the capture area and stand in a T-pose. After that you can act desired motions.
If you make several takes of one actor, we recommend to strike a T-pose in the beginning of each take.
Tip: We use tracking data from modern depth sensors for workflow improvements. You can get most of it if you follow recommendations described here.
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
  • switch to the Scene tab
  • etc.
Manual Clean-up
Cleaning up tracking gaps
Clean-up Steps
Individual body parts tracking
  • Tracking will be done for selected body parts only.
  • Unselected body parts will keep the same rotations.
Cleaning up individual frames
Automatic Refinement and Filtering should be applied after Manual Clean-up, if there were tracking errors.
Also, this final step is called Post-Processing and includes:
Clean-up Steps
  1. Tracking Refinement
  2. Jitter Removal
  3. Trajectory Filtering
Tracking refinement
Important! Refine should be applied:
  • Using the same tracking parameters as the primary tracking (e.g. feet tracking, head tracking) in order not to lose previously tracked data.
  • Before motion controller data.
  • If you plan to manually edit the animation (not related to automatic cleanup with Refit Pose).
In contrast to the primary tracking, Refine does no pose prediction. It is based on the current pose in a frame only. Essentially, running Refine is equal to automatically applying Refit Pose to a range of frames which were previously tracked.
  • Jitter Removal filter is a powerful post-processing filter. It should be applied after cleaning up tracking gaps and errors.
  • It is recommended that you always apply Jitter Removal filter before exporting animation.
  • Jitter Removal filter suppresses unwanted noise and at the same time preserves sharp, dynamic motions. By design, this filter should be applied to relatively large segments of animation (no less than 50 frames).
  • Range of frames affected by Jitter Removal is controlled by current Region of Interest (ROI).
  • You can configure Jitter Removal options for specific body parts. Default setting for Jitter Removal “aggressiveness” is 1 (one tick of corresponding slider). Oftentimes, you can get better results by applying a slightly more aggressive Jitter Removal for torso and legs. Alternatively, you may want to use less aggressive Jitter Removal settings for sharp motions like martial arts moves.
  • Jitter Removal filter makes an internal backup of all data produced by tracking and clean up stages. Therefore, you can re-apply Jitter Removal multiple times. Each subsequent run works off original tracking/clean-up results and overrides previous runs.
  • Trajectory Filter is a traditional digital signal filter. Its purpose is to filter out minor noise that remains after Jitter Removal filter.
  • Trajectory Filter is very fast. It is applied on-the-fly to current Region of Interest (ROI).
  • Default setting for Trajectory Filter is 1. Higher settings result in multiple passes of Trajectory Filter. It is recommended that you leave it at the default setting.
  • Trajectory Filter can be useful for “gluing” together multiple segments of animation processed with different Jitter Removal options: change the Region of Interest (ROI) to cover all of your motion (e.g. multiple segments processed with different jitter removal setting); change Trajectory Filtering setting to 0 (zero); then change it back to 1 (or other suitable value).
Export and Motion Transfer
Video Materials
