User Guide for Multiple PS Eye Cameras Configuration
Revision as of 13:10, 3 November 2014 by Pavel (Talk | contribs)
    • CPU: x86 compatible (Intel Pentium 4 or higher, AMD Athlon or higher, 2GHz), dual- or quad- core is preferable
    • Operating system: Windows 11 / 10 / 8.1 / 8 / 7 (32-bit or 64-bit)
    • ExpressCard or eSATA slot (for laptops)
    • Storage system: HDD or SSD or RAID with write speed:
      • For 4 cameras at 60 fps, 640 x 480 resolution: not less than 17 MByte/sec
      • For 6 cameras at 60 fps, 640 x 480 resolution: not less than 25 MByte/sec
      • For 8 cameras at 60 fps, 640 x 480 resolution: not less than 35 MByte/sec
      • For 12 cameras at 60 fps, 640 x 480 resolution: not less than 50 MByte/sec
      • For 16 cameras at 60 fps, 640 x 480 resolution: not less than 70 MByte/sec
Note: These numbers are valid for "background subtraction" compression mode (default compression mode for PS Eye cameras in iPi Recorder). But this compression involves additional CPU load. If your CPU is a bottleneck, you can use non-compressed mode that gives 3-5 times higher required write speed, but the CPU load will be reduced.
iPi Mocap Studio
    • CPU: x86/x64 compatible (Intel Pentium 4 or higher, AMD Athlon or higher), dual- or quad- core is preferable.
    • Operating system: Windows 11 / 10 / 8.1 / 8 / 7 (32-bit or 64-bit).
    • Video card: DirectX 11 capable gaming-class graphics card.
Software Installation
  1. Select needed components
Important!
Components
    Device drivers and software libraries for Microsoft Kinect 2. Requires 64-bit Windows 8+ and USB 3.0.
    iPi Recorder itself.
iPi Mocap Studio
All components are required for installation.
Note: The installation of Microsoft .NET Framework 4.8 requires an Internet connection. If needed, you can download offline installer for Microsoft .NET separately, and run it before iPi Mocap Studio setup.
Other components are included with iPi Mocap Studio setup.
Note: Shell Extensions for Video and Project files are needed to show thumbnails and preview for iPi video and project files in Windows Explorer
  1. Press the Install button to begin installation.
  2. You will be prompted to read and accept the license agreement(s) by checking corresponding checkbox.
  3. Press the Install button to begin installation.
  4. Upon installation is complete, you will be prompted to launch iPi Mocap Studio.
  5. As soon as iPi Mocap Studio launches, you will be prompted to enter your license key or start 30-days free trial period.
    For more info about license protection see Licensing Policy.
  6. Ensure that your graphics hardware is set to maximum performance with iPi Mocap Studio.
Recording Video with Multiple PS Eye Cameras
Environment
Space
For a multiple PlayStation Eye configuration, you need a minimum of 13 feet by 13 feet space (4 meters by 4 meters). At smaller space, actor simply won’t fit into view of cameras.
Background
Lighting
Actor Clothing
iPi Desktop Motion Capture has an option of using T-shirt over long-sleeve shirt for actor clothing. The tracking quality should benefit from such clothing because the arms are distinguished better from the torso.
Recording Process
Please run iPi Recorder and follow recording workflow as described in user's guide for the program.
Framerate
4 cameras at 320 by 240 resolution
4 cameras at 640 by 480 resolution at 60 frames per second
6 cameras at 640 by 480 resolution at 60 frames per second
USB controllers
Performance Tips
Recording with multiple cameras is a very resource consuming operation. If the system does not provide sufficient resources, you may experience different problems like frame drops, unstable frame rate, premature ending of recording. All these end up in poor quality records which cannot be successfully processed in iPi Mocap Studio. Below are some recommendations which help you to avoid problems with hardware performance during recording.
  • Use dedicated physical drive (HDD or SSD, or even RAM drive when having enough memory) for recording onto it. When recording onto OS drive, performance may suffer badly from other working processes reading and writing to that drive in parallel.
  • Ensure PC is not set to any kind of power saving mode like Power Saver power plan or Battery Saver mode in Windows 10.
  • Connect laptop to a power line if possible. If not, charge battery to full before going on to recording.
  • Stop programs which perform many computations or disk operations. Examples of such programs are torrent clients and anti-virus software.
  • Unplug unnecessary high-bandwidth USB devices like external drives, Wi-Fi adapters (if not needed for distributed recording).
Scene Set-up
The general rule of thumb is to place most of the cameras at 1 - 1.5m height and one per each 4 at a greater height of 2 - 2.5m. However, for specific motions other setups may be more beneficial. For instance, when an actor is lying on the floor or crawling, you can improve tracking quality by placing more (like half) cameras higher, up to the ceiling level.
Anyway, the system is flexible and you can get decent results with any reasonable setup. Even when you cannot follow all recommendations due to limitations in space or room's geometry.
5 and More Cameras Configuration
You can set up 5 or more cameras in a full-circle or a half-circle configuration, depending on available space. You can improve accuracy by placing one or two cameras high over the ground (like 3 meters high).
Recommended configuration for 6-camera full-circle setup:
Four Camera Configuration
You can set up 4 cameras in a half-circle or a full-circle configuration, depending on available space. You can improve accuracy by placing one of the cameras high over the ground (like 3 meters high).
Recommended configuration for 4-camera setup in half circle:
Example:
Three Camera Configuration
Recommended configuration for 3-camera setup is a half-circle:
Example:
Virtual view of the same scene:
Camera Setup
Install the cameras on tripods and connect cables.
Sony PlayStation Eye cameras do not have standard tripod mounting screw, so you will have to use some kind of ad hoc solution. The simplest approach is to fix the cameras to tripods using sticky tape.
When mixing active and passive USB cables, make sure cable connection order is correct (computer->active cable->passive cable->camera).
If you're using the PlayStation Eye camera, make sure you have the lens set to the wide setting.
Calibration
Calibration
Recording Actor's Performance
Recommended Layout of an Action Video
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
It is preferable to have actor strike a “T-pose” before the actual action. The software will need T-pose for building actor appearance model during tracking.
Tip: It is recommended to face the palms down, as it corresponds to the default orientation of the model's hand bones.
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
Processing Video from Multiple PS Eye Cameras
  • Run iPi Mocap Studio
  • Press Ctrl+N or push New button on toolbar to create new project (1)
  • Select "Action" project type
  • To load camera calibration data, select corresponding calibration project file (.iPiCalib) or scene file (.iPiScene)
  • Adjust the Region-of-Interest (ROI) (2). (Region of Interest should cover the part of video that contains the motion).
  • Go to T-pose frame. Using character Move/Rotate controls, roughly align the model with the image of actor in one view (3).
  • Adjust character height and proportions (on Actor tab) to correspond to actor (4).
  • Push the Auto Detect Actor Colors button on Actor tab to automatically adjust model's colors.
Note: For the multi-camera video, Analyze Actor Colors button uses only one (current) camera. This makes it easier to align model with image. You can refine actor appearance by alternating Refit Pose and Analyze Appearance. Also you can edit the colors manually or with the eyedropper tool.
  • Go to the first frame of Region of Interest (ROI) (5).
  • Push the Refit Pose button on Tracking tab (6).
    • If initial pose was recognized incorrectly, you can roughly adjust it manually and use auto-fit again.
  • Push the Track Forward button on Tracking tab (7).
Note: You can save your motion capture project to a file. If your project is saved to a file, then the system will auto-save it after each processed frame during tracking.
Manual Clean-up
Cleaning up tracking gaps
Clean-up Steps
Individual body parts tracking
  • Tracking will be done for selected body parts only.
  • Unselected body parts will keep the same rotations.
Cleaning up individual frames
Automatic Refinement and Filtering should be applied after Manual Clean-up, if there were tracking errors.
Also, this final step is called Post-Processing and includes:
Clean-up Steps
  1. Tracking Refinement
  2. Jitter Removal
  3. Trajectory Filtering
Tracking refinement
Important! Refine should be applied:
  • Using the same tracking parameters as the primary tracking (e.g. feet tracking, head tracking) in order not to lose previously tracked data.
  • Before motion controller data.
  • If you plan to manually edit the animation (not related to automatic cleanup with Refit Pose).
In contrast to the primary tracking, Refine does no pose prediction. It is based on the current pose in a frame only. Essentially, running Refine is equal to automatically applying Refit Pose to a range of frames which were previously tracked.
  • Jitter Removal filter is a powerful post-processing filter. It should be applied after cleaning up tracking gaps and errors.
  • It is recommended that you always apply Jitter Removal filter before exporting animation.
  • Jitter Removal filter suppresses unwanted noise and at the same time preserves sharp, dynamic motions. By design, this filter should be applied to relatively large segments of animation (no less than 50 frames).
  • Range of frames affected by Jitter Removal is controlled by current Region of Interest (ROI).
  • You can configure Jitter Removal options for specific body parts. Default setting for Jitter Removal “aggressiveness” is 1 (one tick of corresponding slider). Oftentimes, you can get better results by applying a slightly more aggressive Jitter Removal for torso and legs. Alternatively, you may want to use less aggressive Jitter Removal settings for sharp motions like martial arts moves.
  • Jitter Removal filter makes an internal backup of all data produced by tracking and clean up stages. Therefore, you can re-apply Jitter Removal multiple times. Each subsequent run works off original tracking/clean-up results and overrides previous runs.
  • Trajectory Filter is a traditional digital signal filter. Its purpose is to filter out minor noise that remains after Jitter Removal filter.
  • Trajectory Filter is very fast. It is applied on-the-fly to current Region of Interest (ROI).
  • Default setting for Trajectory Filter is 1. Higher settings result in multiple passes of Trajectory Filter. It is recommended that you leave it at the default setting.
  • Trajectory Filter can be useful for “gluing” together multiple segments of animation processed with different Jitter Removal options: change the Region of Interest (ROI) to cover all of your motion (e.g. multiple segments processed with different jitter removal setting); change Trajectory Filtering setting to 0 (zero); then change it back to 1 (or other suitable value).
Export and Motion Transfer
Animation Export
  1. Select Export tab
  4. Select output file format
Motion Transfer
Other rigs
Multiple Target Bones
How to Loop Animation
Unreal Engine
  • Produce text or binary file
DAZ 3D Genesis 8
iClone 8
iClone 3
Step 5
Step 5
Step 6
Video Materials
For video materials please refer to our Gallery
Video tutorials are available
