- 1 System Requirements
- 2 Software Installation
- 3 Recording Video from Depth Sensor
- 4 Recording Actor's Performance
- 5 Processing Video from Depth Sensor
- 6 Tracking Tips and Tricks
- 7 Manual Clean-up
- 8 Automatic Refinement and Filtering
- 9 Export and Motion Transfer
- 9.1 Animation Export
- 9.2 Motion Transfer
- 9.3 How to Loop Animation
- 9.4 Export Pipelines for Popular 3D Packages
- 9.4.1 MotionBuilder
- 9.4.2 3D MAX Biped
- 9.4.3 Maya
- 9.4.4 Unreal Engine
- 9.4.5 FBX
- 9.4.6 COLLADA
- 9.4.7 LightWave
- 9.4.8 SoftImage|XSI
- 9.4.9 Poser
- 9.4.10 DAZ 3D Genesis 8
- 9.4.11 iClone 8
- 9.4.12 iClone 3
- 9.4.13 Valve Source Engine SMD
- 9.4.14 Valve Source Filmmaker
- 9.4.15 Blender
- 9.4.16 Cinema4D
- 9.4.17 Evolver
- 9.4.18 Second Life
- 9.4.19 Massive
- 9.4.20 IKinema WebAnimate
- 9.4.21 Jimmy|Rig Pro
- 10 Video Materials
- CPU: x86 compatible (Intel Pentium 4 or higher, AMD Athlon or higher, 2GHz), dual- or quad- core is preferable
- Operating system: Windows 11 / 10 / 8.1 / 8 / 7 (32-bit or 64-bit)
- Important! Kinect 2 for Windows, Kinect for Xbox One requires USB 3.0 controller.
- Microsoft Kinect 2 for Windows / for Xbox One, or Microsoft Kinect
- Optional: Kinect for Xbox One floor mount
- Minimum required space: 2.5 m by 1.5 m (8 by 5 feet)
iPi Mocap Studio
- CPU: x86/x64 compatible (Intel Pentium 4 or higher, AMD Athlon or higher), dual- or quad- core is preferable.
- Operating system: Windows 11 / 10 / 8.1 / 8 / 7 (32-bit or 64-bit).
- Video card: DirectX 11 capable gaming-class graphics card.
- For more info see Cameras and Accessories#Video_Card.
- Select needed components
- You can plug only one depth sensor to one USB controller. Single USB controller bandwidth is not enough to record from 2 sensors.
Components
- Microsoft .NET Framework 4.5.1 - Client. This is required component and cannot be unchecked.
This is basic infrastructure for running .NET programs. iPi Recorder is a .NET program.- Web installer: http://www.microsoft.com/en-us/download/details.aspx?id=40773
- Standalone installer: http://www.microsoft.com/en-us/download/details.aspx?id=40779
- (Windows 8, 8.1, 10, 11) Microsoft Kinect 2:: MS Kinect SDK 2.0. Check if you plan to work with Kinect 2 for Windows or Kinect for Xbox One depth sensors, but do not plan to connect multiple Kinects to a single PC.
Device drivers and software libraries for Microsoft Kinect 2. Requires 64-bit Windows 8+ and USB 3.0.
- (Windows 7, 8, 8.1, 10, 11) Microsoft Kinect :: MS Kinect SDK 1.8. Check if you plan to work with Microsoft Kinect depth sensors.
- iPi Recorder 4.x.x.x. This is required component and cannot be unchecked.
iPi Recorder itself.
iPi Mocap Studio
All components are required for installation.
Other components are included with iPi Mocap Studio setup.
- You will be prompted to read and accept the license agreement(s) by checking corresponding checkbox.
- Upon installation is complete, you will be prompted to launch iPi Mocap Studio.
- As soon as iPi Mocap Studio launches, you will be prompted to enter your license key or start 30-days free trial period.
For more info about license protection see Licensing Policy. - Ensure that your graphics hardware is set to maximum performance with iPi Mocap Studio.
Environment
| Configuration | Azure Kinect (WFOV mode) | Azure Kinect (NFOV mode) Kinect 2 (Kinect for Xbox One) |
1st gen. Depth Sensors Orbbec Astra (Pro) |
| Single Depth Sensor |
7 by 5 feet = 2 by 1.5 meters |
8 by 5 feet = 2.5 by 1.5 meters |
10 by 10 feet = 3 by 3 meters |
| 2 Depth Sensors (90-degrees config.) |
7 by 7 feet = 2 by 2 meters |
8 by 8 feet = 2.5 by 2.5 meters |
| 2 Depth Sensors (180-degrees config.) |
12 by 7 feet = 3.5 by 2 meters |
16 by 8 feet = 5 by 2.5 meters |
20 by 10 feet = 6 by 3 meters |
| 3+ Depth Sensors |
12 by 12 feet = 3.5 by 3.5 meters |
16 by 16 feet = 5 by 5 meters |
20 by 20 feet = 6 by 6 meters |
Maximum capture area is about 7 by 7 feet ( = 2 by 2 meters), for all sensor models and configurations.
The pictures below will help you to understand possible capture area and required space. Dimensions are different for Azure Kinect, Kinect 2 (Kinect for Xbox One) and 1st gen. depth sensors due to different field of view.
Azure Kinect in NFOV mode and Kinect 2 for Windows (Kinect for Xbox One)
Kinect 2 (Kinect for Xbox One) sensors and Azure Kinect sensors in NFOV mode (narrow-view mode) have very close view angles (less than Azure Kinect in WFOV mode, but greater than 1st gen. depth sensors and Orbbec Astra):
Wide-view mode (WFOV mode) of Azure Kinect has extremely wide view angle:
First Generation Depth Sensor or Orbbec Astra (Pro)
If you're using outdated 1st generation depth sensor like Kinect v1 or Orbbec Astra (Pro) sensor which is almost the same as 1st gen. depth sensor:
Actor Clothing
Recording Process
Please run iPi Recorder and follow recording workflow as described in user's guide for the program.
After completing Setup and Background recording steps, press Record button to begin video recording. To stop recording, press Stop button.
Recommended Layout of an Action Video
- Enter the actor.
- Strike a T-pose.
- Action
T-Pose
As soon as recorder starts, go to the capture area and stand in a T-pose. After that you can act desired motions.
If you make several takes of one actor, we recommend to strike a T-pose in the beginning of each take.
Takes
Iterations
- Record the videos
- Process the videos in iPi Mocap Studio
- Import your target character into iPi Mocap Studio and review the resulting animation
- Give feedback to the actor
Takes
Naming conventions
- Run iPi Mocap Studio
- Press Ctrl+N or push New button on toolbar to create new project (1)
- Choose recorded *.iPiVideo file
- After video opened, the floor will be calculated automatically and position of camera will be detected based on floor plane.
- Right mouse button up
- Save created project by pressing Ctrl+S or pushing button Save on toolbar (2)
- Position timeline slider to the frame where actor is in T-pose (3)
- Adjust actor height using appropriate slider on tab Actor (4)
- Select Move tool on toolbar. (5)
- Switch to Tracking tab and push Refit pose button. (6)
- As a result model should be matched with actor image from video. If it does not happen then delete result using item Edit > Delete pose from main menu and repeat above actions.
- Using the slider right to the button Show Skin in toolbar, make sure that morph of model corresponds to the actor image (7).
- If no, than adjust chest/bust/waist/hips/belly morph using appropriate sliders from Actor tab (8).
- Set the beginning of Region-of-Interest (ROI) to the current frame with T-pose by pressing I key on keyboard or by double-clicking on the left edge of ROI bar under timeline (7).
- Switch to Tracking tab, change tracking options (Head tracking, Shoulders and Spine) if required (9).
- To start tracking just push Track Forward button (10).
- Wait and watch...
Using Pose Mismatch View
Pose Mismatch window is a very useful tool which allows you to understand how actor settings affect tracking.
- Pose Mismatch window is shown using View > Pose Mismatch menu item
- Mismatch number at the top evaluates how actor model matches to video in the current frame
- You need to run Refit Pose to match actor model to video before comparing Mismatch numbers
- Lower value of Mismatch number means better match. So your need to minimize Mismatch number while choosing settings
Manual Clean-up
Cleaning up tracking gaps
Individual body parts tracking
- Tracking will be done for selected body parts only.
- Unselected body parts will keep the same rotations.
Cleaning up individual frames
Automatic Refinement and Filtering should be applied after Manual Clean-up, if there were tracking errors.
Also, this final step is called Post-Processing and includes:
- Tracking Refinement
- Jitter Removal
- Trajectory Filtering
Tracking refinement
- Using the same tracking parameters as the primary tracking (e.g. feet tracking, head tracking) in order not to lose previously tracked data.
- Before motion controller data.
- If you plan to manually edit the animation (not related to automatic cleanup with Refit Pose).
In contrast to the primary tracking, Refine does no pose prediction. It is based on the current pose in a frame only. Essentially, running Refine is equal to automatically applying Refit Pose to a range of frames which were previously tracked.
- Jitter Removal filter is a powerful post-processing filter. It should be applied after cleaning up tracking gaps and errors.
- It is recommended that you always apply Jitter Removal filter before exporting animation.
- Jitter Removal filter suppresses unwanted noise and at the same time preserves sharp, dynamic motions. By design, this filter should be applied to relatively large segments of animation (no less than 50 frames).
- Range of frames affected by Jitter Removal is controlled by current Region of Interest (ROI).
- You can configure Jitter Removal options for specific body parts. Default setting for Jitter Removal “aggressiveness” is 1 (one tick of corresponding slider). Oftentimes, you can get better results by applying a slightly more aggressive Jitter Removal for torso and legs. Alternatively, you may want to use less aggressive Jitter Removal settings for sharp motions like martial arts moves.
- Jitter Removal filter makes an internal backup of all data produced by tracking and clean up stages. Therefore, you can re-apply Jitter Removal multiple times. Each subsequent run works off original tracking/clean-up results and overrides previous runs.
- Trajectory Filter is a traditional digital signal filter. Its purpose is to filter out minor noise that remains after Jitter Removal filter.
- Trajectory Filter is very fast. It is applied on-the-fly to current Region of Interest (ROI).
- Default setting for Trajectory Filter is 1. Higher settings result in multiple passes of Trajectory Filter. It is recommended that you leave it at the default setting.
- Trajectory Filter can be useful for “gluing” together multiple segments of animation processed with different Jitter Removal options: change the Region of Interest (ROI) to cover all of your motion (e.g. multiple segments processed with different jitter removal setting); change Trajectory Filtering setting to 0 (zero); then change it back to 1 (or other suitable value).
Animation Export
- Select Export tab
- Select output file format
Motion Transfer
Other rigs
- Select Export tab
Multiple Target Bones
Unreal Engine
- Produce text or binary file
DAZ 3D Genesis 8
iClone 8
iClone 3
