Main Page
Revision as of 12:53, 18 October 2014 by Andrew (Talk | contribs)
iPi Motion Capture consists of the following products:
iPi RECORDER
free software for making records
iPi MOCAP STUDIO
paid software for processing records
(free 30-days trial is available)
iPi BIOMECH ADD-ON
in-depth biomechanical analysis of human motions
iPi AUTOMATION ADD-ON
allows to control iPi Recorder and iPi Mocap Studio from external application
Frequently Asked Questions
Licensing Policy
h o t a r t i c l e s :
AI-based Tracking
Real-time Tracking for Live Preview
Animation Streaming to Unreal / Unity
Maximizing GPU Performance
P o s s i b l e   C o n f i g u r a t i o n s :
Multiple PS Eye Cameras Configuration
The configuration with multiple (up to sixteen) RGB cameras is the most powerful option. It allows you to track very complex motions in a big capture area: up to 20 by 20 feet or 7 by 7 meters.
Web Cameras
Sony PS3 Eye cameras are recommended as they give good-enough quality of video at up to 60 FPS. Logitech C922 web camera is also good option but it is more expensive.
six C922  |  four PS3 Eye
  • System Requirements:
for Recording  |  for Processing
Action Cameras
You can use almost any stand-alone camera models with fixed focus, high FPS and wide view-angle. We recommend GoPro or SJCAM action cameras because of their popularity.
Editions: Basic, Pro (?)
Multiple Depth Sensors Configuration
Multiple depth sensors configuration combines ease of use and flexibility of a single depth sensor with power of multi-camera system. With two or three or four depth sensors like Azure Kinects, Orbbec Femto, Microsoft Kinects 2 (Kinects for XBOX One), or other depth sensors animators can accurately capture complex motions including 360-degrees turns.
two MS Kinects 2  |  two Azure Kinects
Single Depth Sensor Configuration
iPi Soft uses its own tracking algorithms that give much better accuracy than other Kinect/Orbbec/Xtion-based motion captures available in the market. This configuration is very easy to use, as it does not require calibration. For those who haven't had experience with motion capture systems before, it is a good option to start from.
single MS Kinect 2  |  single Azure Kinect
Editions: Express, Basic, Pro (?)
Common Features for All Configurations
Distributed Recording
Using two or more computers one can record synchronized video from multiple devices part of which are connected to one computer and others are connected to different computer(s).
Motion Controllers
Using motion controllers like PS Move, Wii Remote with MotionPlus and Wii Remote Plus one can track hand, prop and head movements.
Hand Keyframing
iPi Mocap Studio includes keyframing feature to manually set poses for fingers.
Manual Clean-up
Tracking errors usually happen in a few specific video frames and propagate to multiple subsequent frames. iPi Mocap Studio provides capabilities to correct such errors in a manner of seconds.
Automatic Refinement and Filtering
To achieve high quality results one can use build-in motion refinement and filtering tools. This allows to obtain realistic jitter-free animation without need to use special 3d-party packages like Motion Builder.
Animation Export
iPi Mocap Studio can export result animation in various formats including FBX, BVH, Collada, DMX and SMD. Also iPi Mocap Studio supports various rigs and has build-in motion transfer capabilities.
Pro Edition Exclusive Features
Multiple Actors
Pro edition supports multi-person tracking. This feature allows to track dancing, fighting, etc.
Sample Video and Project
Multiple GPUs
Using Pro edition you can use multiple GPUs to speed up tracking.
Batch Processing
Instead of being "babysitter" for iPi Mocap Studio you can "record" a set of all required actions to batch and then start them by one click.
